Northskytrail22
Morning all I removed my factory hood scoop from my 2022 trailboss in prep for carbon fiber wrap . It’s a nightmare getting this thing off the 8 nuts come off really easy then it’s the 14 pinch clips that are really the problem you can get to the two center one and the 6 rear ones fairly easy it’s the fronts that are impossible I had to drill tiny puppet holes into the dimples in the bottom of hood then use a step bit to make it large enough to put a small flat head screwdriver to pop them up the two center corner clips you can access through bottom Gm gave you no points and you can’t drill them so once you get all them out reach under and pop with scre driver and will come off. There is a piece of foam around bottom but it’s only a 1/4 inch wide and looks like a blind person put it on cause it doesn’t sit on the edge where the scoop touches the paint and yes I’ve had chipping around all four corners. I bought 12 inch wide foam and plan on doing what Gm should have done at the factory the first time for a 65,000 truck. It took me about 3 hours to get this piece of plastic off my hood. I love the foam passes sticker truck made in Mexico lol anyway anyone doing this is welcome to ask ?s im no pro just got it done.
