I have Mickey Thompson Baja boss 275/70/18. Zero trim or rubbing even with mud flaps. I think it fills very well so I haven’t felt the need to go bigger. You may want to see if anyone else has gone bigger with the actually delete.275 / 70 / 18 is a 33 inch tire. Standard on my TB LT is 275 / 65 / 18 a 32 inch tire.
Your choice, but you can use this comparison tool to compare apples to apples. My experience is you can usually go 1 size up for just about any tire.
Tire Size Comparison
Tire size comparison the easy way. Use our tire size comparison calculator to compare diameter, width, sidewall, circumference and revolutions per mile.tiresize.com
Even with 20in stock rims?I have Mickey Thompson Baja boss 275/70/18. Zero trim or rubbing even with mud flaps. I think it fills very well so I haven’t felt the need to go bigger. You may want to see if anyone else has gone bigger with the actually delete.
Not sure about the 20inch rims.Even with 20in stock rims?
