2022 - Warranty , inner drivers side door weatherstripping.
DForm
East Greenwich,RI 02818
2022 Trail Boss LT
Heads up - I’m sure some of you might run into this lsame issue. I purchased my TB in August of 2022, and currently have just over 2,000 miles on it. I was shocked when getting into the drivers side door to see that the weatherstripping down at the door sill had a long cut in it. I bought it to the dealership and it’s covered under the warranty. After looking at what might have caused this I ran my finger along the edge of the plastic door sill and found it to be very sharp. Any pressure put on this undoubtedly was the cause of the cut. I’m sure this is probably going to be the same on the other three door sills. I’m thinking of putting a plastic edging on the door sills to fix this. You all may want to check you TB’s for this issue.
