2023 Trail Boss with 3.0Diesel- 35" tires
bferg911
Round Rock, Tx
2023 Silverado trail boss LT 3.0 duramax
2023 Chevy Blazer RS
Looking for some help with what I'm looking at for mileage and performance when going to 35" tires. Always had gas before and included a gear change everytime I did a lift and bigger tires. This is my first diesel and 10 speed trans so I have no idea what kind of drop I will see. I just like to get everything done at once and if that needs to be gears too then so be it, But just curious what y'all have seen. Thanks in advance
What are your plans for a lift or level and wheels. I know not what you are asking but I have a refreshed 22 with the diesel and I have less than a 1/2" of clearance between the UCA and tires all stock. Everyone on here talks about wide tires on stock setup but I can't even get 285s (I tried ) without hitting UCA. I bought 1.5" spacers to add clearance. I am running 275/65/20 which is a 34" tire.
I'm looking to do a BDS 4" coil over lift and 35's. Basically the same set up I had on my 2012 Z71 but with that I absolutely had to put gears in it.
With a 10 speed tranny and diesel torque I am just curious what the result will be without gears.
