2024 2” ReadyLift SST
BC_Hunter
BC
Chevy Trailboss
Just got it done today.
Tires: Mickey Thompson Baja Boss AT
295/70/18
Wheels: 18x9
Method NV 305 Double Black
Looks good 👍🏻 Did you do the rear block as well or just the front?
Yes I did the rear block as well as I do a lot of towing.
So Mr. Naive over here is hazy on what you mean by "block". Is it a block to lift or a block on the leaf to help minimize rear droop when towing?
It's just a 3" block to lift that replaces the stock 2" one.
Not really because the front end was raised 2".
Does that one extra inch do a lot to minimize the droop for you?
this 3" block would give you a higher DROOP measurement from a raised position. overall travel would be the same, just 1" lower at each starting point.
295/70/18
Wheels: 18x9 View attachment 17272Method NV 305 Double Black
Looks great. any idea on the overall height? I'm trying to figure out if I'll still be able to park in the garage!
I have a 19 Custom that has the RC 1.5 leveling, sits on 35x12.5x20s. my height from ground to top of my xm antenna(above driver seat) sits at 79".
