305/70R18 BFG HD-TERRAIN
MrGoodwrench
Reidsville, Ga
2023 Trail Boss
2023 Cadillac XT6
Ga Air Guard (71-78)
Do anyone know if 305/70/18 tires will fit without rubbing ? I have RC 1.50“ level kit and .50 wheel spacers. Have stock 275/65/18 now. Looking at the NEW BFG HD-TERRAIN T/A KT IN 305/70. Any help appreciate. THANKS David
I just put on some 295/70r18 Toyo R/T Trails and have no rub at all. My truck is still factory height too. So with a 1.5" level kit I would thing a 305/70 should fit just fine...The main issue could be whether or not they rub the UCAs. I still have a half inch clearance but that would be the main concern.
Thanks Matt, I also have 1/2 wheel spacer, so that will also help with UCA clearance 305's
Mostly and issue in reverse so you may need to play with spacer thickness.
0.5” taller and 0.5” wider ish than the 295/70’s a lot of members are running. I say go for it and let us all know how it works out so we know if we can all go bigger 😬😂
I have 305/70/18's BFG KO3's on my 2025 LT TB and it did rub when it was turned at 95% to full lock. I have 2 inch wheel spacers as well as a 4 inch Zone Offroad suspension lift. I had to do some minor fender lip rolling and Sawzall cuts.
