35x12.5x18 BFG KO2 -- who's running them?
07blackz71
Cedarburg, WI
Who is running 35x12.5x18 BFG KO2? On stock suspension and stock rims?
I have a Ready lift 1.75" kit I am putting on when it warms up. But I found a set of take off BFG KO2 35" tires at a decent price. I was hoping I can run these at stock height until I upgraded the suspension. Is anyone running on stock suspension? If so do they clear the body? And do they clear the UCA?
https://www.trailboss.org/threads/show-and-tell-wheels-and-tires.1037/#post-9837 this was a post of mine regarding my leveling and what I went to. I do get some rub up front at full turn(fwd/rev) but manageable. my front flaps are about 2/3 cut but are still mounted with the 3 screws. stock suspension but bumped up to 20in wheels
I’m running the BF Goodrich 35-12.50-18 on The BDS lift.. I also have-12 offset wheels on it.. I deleted the fenders and still get slight rub in reverse on full lock.. Just giving you and idea of what I have…
I am getting ready to put on 295 70R18 and have already did the 1.75 leveling kit. My question for anyone who has done the leveling kit is whether they are getting a lot of front end noise on bumps or dirt roads. Seems to be fine straight on hardtop but lots of noise on gravel and bumps. I rechecked everything and it is all tight. Anyone else have this issue?
Going to pick these up tomorrow for $1300. Like brand new with less than 50 miles.
We will see in a week or two if they will fit at stock height.
Hopefully everything works out for you my friend..
Just got back. They are brand new!!
They should fit. Will be using stock wheels. I currently have the front lifted 5/8" over stock. If they don't clear I will put on the RL 1.75" kit. I also have a set of Bora 10mm slip on spacers if they rub the uca.
Keep us updated. I have the RL 2.0 SST kit and I want to add 35/12.5r18 on my stock wheels . I think I my need 1.5 wheel spacers
Finally installed te tires today. They clear the UCA's and so far no rubbing. I might have to trim the front weathertech mudflaps. The change the look of the truck.
Great looking setup.
just to be clear, that is stock height on an otherwise stock truck right? any spacers?
Thanks
I have the front lifted 5/8". I have no wheel spacers. I can fit my fingers between the tire and the UCA. About .5".
