6L80E - 6 speed trans fluid check
Paul Wisenbaker
Conroe, TX
20 Trailboss
Is there a way to check the trans fluid with these dip-stick less transmissions? I want to upgrade the trans pan. Thanks for the help.
The drain plug really isn't a plug, that's where you check fluid level. There a small decal on the pan that illustrates. The fill plug is on the right side of the case where a dipstick tube would normally be, that's the fill port. The exhaust shield will need to be removed. You can take a look with a flashlight and mirror..
Thank you
