Adding Rough country 6” (4” on TB). How tall will it be with 35” tires?
rmarsh0505
Ozona
2019 Chevy trail boss
Trying to find out if anyone has the Rough country 6” (4” on TB) & How tall will it be after adding 35” tires. Worried about it not fitting in my garage and know how to do the math but want to make sure. I have around 7 inches to still fit
go add the 4"to your current, then figure the tire height difference...half of that will be added to your 4"
you have a 33" tire now ??? add an inch of tire to the 4"...so roughly 5" to your current for tight measurements...or go add 6" to your roof and see
Yeah figured that, just trying to find someone that has that setup done and what they are sitting at now with the 35” they have now. Most 35” aren’t truley 35’s. And with the lift they usually settle making them a little lower. Do you have this setup?
i do not, i have a 1.75 level and a 34" tire
This should be the math.
With 7 inches clearance to go:
-4 for the lift
-1 for the 35 tire up from 33
Net 2 inches of clearance remaining.
Ready lift 2.0 which comes with upper control arms and rear block lift as well.. 35/12.50/18’s KO2’s zero offset ICON’s, RC mudflap delete, Bilstiens 5100’s… a lower center of gravity and no cutting cross members and no need to run 20’s .. zeros issues going on 30K miles with this lift… had the 1.5 RC level prior to the ready lift
Agree, doing real Lifts like a 6 on these 1/2tons in my mind is a waste. Just get an HD like the Ram PW, ZR2, AT4X and save yourself a mountain of on-going headache risks. You'll have a more capable truck in the HD and its designed from the factory, to actually be tall.
