JGrill
What are you guys using for your air filters? I’d like to go k & N but don’t want to shell out 75.00. Has anyone had good experience with these knock off AC delcos on Amazon?
Good point. I most likely will go with the k &n. I’ve already got the charge kit from previous vehiclesI did go with the drop in K&N. The truck comes stock with a high intake large box air filter so I see no need to go with a CAI. I see it as the 75 bucks saved me 400 over a CAI.
Agree to disagree. Both have their pros and cons. For example, I have a warranty backed by GM on my intake.Or buy the drop in replacement and be WAY more ahead. I put an AFE dry flow in mine. I later put the K&N kit that just replaces the silencer from the stock airbox to the throttle body. I didn't use the drop in filter from K&N. It's just sitting in a box in my barn.
You couldn't agree to disagree, huh? Even my filter has the warranty. $600 included a tune at the dealership to ensure my truck runs optimally with the CAI. How much would a tune run you? Last I checked, about $2,000.Me too, the factory one I didn't spend $600 for!
I just installed the S & B over the weekend. They said the amount of oil to use is critical, I think was around 8-9 oz. If you look up the filter # it will tell you the exact amount in grams, then you can convert it. I left the side plug off and boy does it sound good, reminds you of the 4 barrel kicking in from years ago! One thing they need to do is make a tighter fit for the rubber plugs on the airbox, a lot of people complain about them falling off when trying to squeeze the new box in as it's a very tight fit. I lost one too and luckily the ones on the factory box were the same size and I used one of them. If you noticed, the inside of the air tube is very slick so that it won't hinder air flow.I really have no input. I removed all the factory air cleaner and piping within the first 100 miles. Went with the S&B and never will look back. Clean it myself and respray it and all good. I like the large surface area it offers.
Just looked up specs on the GM CAI and it only reduces air flow restriction by up to 17% for the 6.2 and 13% for the 5.3. I don't really see how that would help very much as most of the aftermarkets in around 50%.Go with the GM intake. As others have said they reprogram the ECM for it. If not just run the GM filter. I have seen soo many issues with people running K&N and ruining their MAF sensor.
