Any one running 35x12.5 on stock TB wheels with Ready Lift 2” SST leveling kit
TGomez
626Tb730
2019 Trail Boss LT
Hi I’m new to this forum and want some info and help for mods on my TB. Is any one running 35x12.5 on stock TB wheels with Ready Lift 2” SST leveling kit ? If so did you need spacers? If yes what brand and size of spacer? Thank you in advance 🙏🏻👍🏻
It makes a difference on what size wheel? 18 or 20?
The spacers will add clearance between the tire and UCA upper mount but will exacerbate the rubbing in the mudflap/ fender liner area. An easy fix though.
I recommend BORA wheel spacers since they’re hub-centric and wheel-centric for a perfect fit… plus made in ‘Merica.
18 inch tires definitely rub more than an 20 inch tire, it’s because more rubber on a smaller wheel if that makes sense… I do have slight rub in reverse @fulll lock running K02 35x12.50x18 on BDS 4 inch lift on LT Trail boss.. I’m also running-12 rims which will cause it to rub more then the 0 offset of stock rims..
