Anyone else's door speaker grills clogged? This is taking forever to fix!
HopnDude
Home
2022 Chevy Custom Trail Boss 6.2
1994 S10 Turbo 4.3
Maybe, Super Secret Squirrel
Thankfully it was only the one door panel. Took about an hour and a half.
It was from a bad mould process. About 60% of each hole had plastic from the moulding process left in them. I took a Carb Jet bit/tool at 0.065" and went through them to push/cut the excess plastic out.
If you look at the first photo, you can see the few circles that aren't problematic, but if you look at the other 98% the center looks significantly smaller.
Looking at the second photo, you can see all the holes are now closer in diameter.
