Anyone running Nitto Ridge Grappler 35x12.5xr18 with a leveling kit?
th0mas09
Arizona
2021 Trail Boss Custom
Army
Looking to possibly put on 35s and I put the Readylift level kit on my TB. If you have pictures that would be great or rubbing if you had to trim.
I have the BDS 4 inch lift kit = to 6 inches running 35-12.50-18 and still get slight rub backing up in reverse with full wheel crank.. I also did the fender delete… you definitely will get rubbing in reverse and most likely in drive with the wheels fully cranked..
I can get pictures for you tomorrow with the wheels fully turned to see the distance I have with the BDS lift.. Will help give you an idea of what I’m talking about..
I’m also running aftermarket wheels so that plays into the rub too.. I have -12 offset 18X 9.5.. Stock wheels might work with what you are trying to accomplish..
I agree. I have the same lift and aftermarket rims. Good luck!
