Rvrslt1
- Joined
- Jul 12, 2022
- Messages
- 6
- Media
- 6
- Reaction score
- 5
- Location
- Torrance CA
- Current Ride
- 2022 Chevy Trailboss
- Current Ride #2
- 2012 Jeep Wrangler Unlimited
Did you do full Baja prerunner kit or their UCA? I had a leveling kit on mine and after the UCA/LCA and king install it got lowered about 3”?King coil overs up front that lifted it about an inch. Tires are 315/70R17. Rear also has Kings.
Ride is so much nicer than stock.
Yea I’ll send you a pic before and after. The whole kit widens the truck by 6” so I think the width lowers it more. But I contacted PAX power (they build the Chevy jackal) they install a 2” leveling kit on all trucks after the kings and kit.I just did the UCA and the Kings.
Are you saying your truck was lower with your kings installed?
Yea I was lost when they sent me the first picture below, that picture is kit, shocks installed. I thought I would get a lift or it would be the same as with just a leveling kit.Interesting. So the picture of the truck on the ground is how it sits now with the pre runner kit along with the leveling kit? Looks good.
I am looking for a vehicle lift. Can you find out from the shop in your photo what type of lift that is and where I can find one to purchase? Thanks!Yea I was lost when they sent me the first picture below, that picture is kit, shocks installed. I thought I would get a lift or it would be the same as with just a leveling kit.
No the ground pic is before the kit with just the leveling kit.
The picture on the lift is with the kit, king shocks, and level kit back on, and Deaver springs in the back.
www.ltwmotorsports.com
Stormin08, not sure if you were replying to me. If you were, I was actually asking about the vehicle lift, not a lift kit. I am looking for a decent vehicle lift at an affordable price. I am starting to get sick and tired of using a floor jack and jack stands all the time. I would like to buy a vehicle lift if one is affordable. Thanks.here are some rough ideas,
19-26 Silverado/Sierra 1500 Mid Travel Kits
We specialize in everything aftermarket for your Vehicle with a focus on Performance Suspension Systems that not only give your vehicle lift but also increase on and off road performance. We only carry the top brands in the industry, so you can be sure you are getting the best products and the...www.ltwmotorsports.com
then add a deaver leaf or mini pak....
here is a FOX 2.5 set 3.5" with a 1/4" lower spacer on a 35" tire
Same truck, same front set up...but a deaver mini pak, no overload leaf and 1 of the 1/4" deaver spacer...on a 37" tire
( i have since removed the 1/4" rear spacer, it sits far more level...but still a slight rake. i am planning on a 1.5" block and then trying the 1/4" spacer again)
