I’m sure you could, as long as the Bilsteins are at stock height, but setting them at max height accomplishes the same thing as the top spacer. This also allows you to use the factory nuts on top of the coilovers, which are beefier and will then have more thread engagement as intended. The plastic pieces that sit on top can then still attach as intended to the excess threads. Another benefit is that you won’t have excessive droop when the front wheels are off the ground which puts more strain on the universal joints. Probably not really a concern unless you off-road really hard, but still. You can certainly then still use the bottom spacer if you need it, or are raising the back as well, but mine’s level without.
