Build Quality Issues
dshukwit
33269 Janet
2023 Trail Boss
Has anyone experienced this with Grill and Fascia pulling apart. Not happy when you buy a new truck and it looks like it is falling apart. If I press the right side in the left side comes out. Dealership says this happens on all the new trucks. They showed me several new trucks with the same problem. They said there was nothing they could do.
It's unclear where you are referring. Can you explain more? I'll go out and check mine.....
Reactions: JBJ
Non structural pieces are flimsy as hell these days👎.
Where the grill meets the fascia, You can see the gap between the two. if I push this side in the other side gaps, poor engineering.
Tech at auto nation told me these trucks are made with recycled plastic water bottles and beer cans..
I wouldn't care if its normal or not, it shouldn't happen. Whether poor engineering, poor manufacturing, or whatever, a $50K+ truck should not have front end pieces flapping around on it.
Mine doesn’t have this issue. Nor does it move easily when pressed.
