Elk Hunter
- Joined
- Nov 8, 2020
- Messages
- 29
- Media
- 10
- Reaction score
- 24
- Location
- Cold Springs Nevada
- Current Ride
- 2020 Trail Boss
I got bit by the OEM rear differential cover catching a rock on the extended lip causing a small fluid drain and ended up blowing the rear axle.I wasn't aware of the issue till the Service Manager at Chevy told me to check on line, it's a known problem that GM won't step up and claim.
I'm trying to find a new aftermarket cover and skid pan. AEV shows a cover but states in for RPO code SU7. My RPO code lists "SU6-SU8 subaxle supplier". It's a G80 and RPO GU5 3.23 rear axle ratio.
This tells me that the AEV skid pan, is not for my truck, but per the RPO is it an SU6 or SU8?
