PistolsFiring
Well-known member
2022 Limited LT, 5.3, 21,2xx miles.
Started the truck up Sunday, drove for 2-3 minutes and check engine light comes on. Not a mechanic but no noticeable issues or changes in performance, noise, or driveability. Got to where I was going, turn truck off for a couple hours. Start back up, light still on, go to OReillys and they pull code P219A. Light stays on back and forth to work Monday. Start truck up Tuesday morning, light off and remained off since.
Few searches seems like it’s a generic code if the pre-cat sensors detect a lean or rich situation: ranges anywhere from bad fuel, vacuum leak, bad O2 sensor all the way to bad injector, bad fuel pump/filter, MAF sensor ect. I know any station can get a bad tanker of gas but fill up at the same station, 87 non ethanol. At the dealer today for them to take a look. Hopefully it stored permanent since light went off so they can atleast see it.
Anyone ran into this and since troubleshooting is broad, know what it typically points to as problem?
