EGR Weather Deflectors
CarbonfiberKid
Michigan
2023 Trail Boss 3L Duramax
Anyone have the GM accessory Weather Deflectors in by EGR. I am not finding very many reviews for EGR. How did they fit? Are they worth buying? I was going to use some rewards point to purchase them vs AVS or Weather tech. Thanks
Did exactly what your thinking of doing. Used reward points and got them. They look and fit perfectly fine. I got the in channel ones in dark smoke
Do NOT get the WeatherTech ones! I have them and they rest on your rubber window trim, took a whole three months to cut a hole right through the trim.
I Have the Weather Tech In Channel & if they Rub a hole thru my Weather Strips then I will be calling & complaining.. They definitely should pay for the strips & then get Reimbursed on the Visors.. Only Complaint so far on mine is on Warm / Hot days the Drivers side window will Rebound when Closing unless I slightly pull on the Drivers window switch.. Annoying...
Took these today. Driver's side sits slightly different than the passenger side. Passenger side doesn't seem to be cutting in.
Not sure if wrong or right but I tucked my weathertech in channels further down so they don’t rest on top. 🤔
