dish
- Joined
- Jan 24, 2024
- Messages
- 9
- Media
- 1
- Reaction score
- 9
- Location
- Holland, MI
- Current Ride
- 2021 Silverado LT Trail Boss
I just had to take my truck in because it was misfiring.
I’ve got a 2021 Silverado/Sierra with the 5.3 and 10-speed, just rolled 100k miles. First time I brought it in, they suspected carbon buildup. They ran a cleaner through it and gave it back. About 5k miles later, same issue again. They ran the cleaner again, said it wasn’t uncommon to need more than one treatment—but it still didn’t solve it.
At that point they pulled the intake to check the valves. Turns out there was way more carbon buildup than expected, even after two cleanings. The tech referenced Bulletin No.: 16-NA-383 and said my valves had about double the carbon compared to the “before” pictures in that bulletin.
Their recommendation now is to walnut blast the valves, which should remove 95% of the carbon. That’s fine short-term, but it doesn’t address how the carbon got there. I know oil consumption is common on these engines, mine just gave me a low oil warning right as I was due for a change (7–8k miles after the last one). So both me and the tech are assuming oil consumption is what caused the buildup.
So now I’m trying to figure out the best path forward. The way I see it:
1) Clean it and drive it - Add oil when needed, run top-tier fuel, monitor the carbon buildup.
2) Address oil consumption – Worst case I’m into pistons and rings, which is $$$.
3) Trade it in – Don’t really want to because I like the truck, but it’s an option.
I’ve also been considering an AFM delete—does that actually help with oil consumption? Any downsides?
Would love to hear what others have experienced or what you’d do in this situation.
