Infotainment Climate Control Screen
CharlieCanuck
Ontario
When I took delivery of my new TB (not the refresh model) in 2022, the truck came without heated seats and heated steering wheel. These were to be installed at the dealer when the parts (chips?) became available. I now have the heated seats and heated steering wheel parts installed and they are both working by the manual control buttons when the truck is running.
When I use the remote start by the key fob or app on winter mornings, the heated steering wheel does come on and the seats seem somewhat warm, but not quite as warm as the low setting on the dashboard control buttons.
I have attached a pic of my infotainment screen showing what options are available in the climate control section as well as a screen shot of what options are available (if installed) from the owners manual.
My question is, does anybody else have the "Auto Heated Seats" disable/enable switch on their infotainment screen in the climate and air quality screen? I am just wondering if the system was not updated when the parts were installed or is this one of the options not available to be on the system. Just curious as to what others might have on their 2022 screen for this.
I have the exact same truck as you, 2022 LTD. Wife is out with the truck right now, but when she gets back I will check the options and report back.
Mine looks the same as yours.
But...
If you look under Remote Lock, Unlock, and Start, you will see the heated seats option. If it's not there then the dealer forgot to enabe it when the did the retrofit.
Thank you! I found it. Not exactly where the owners manual says it is. And it was turned on, explaining why the seats were slightly warm when I get in the truck after a remote start on a cold day.
i believe my 23 has the auto, as well as a co workers new 25....i just showed him all the adjustments, and we turned the seats off during auto start
