Is anyone running 285/75’s
TheShadow
Indiana
2020 Lt Trail Boss Crew Cab
2020 LT Trail Boss. Curious if anyone is running 285/75’s on the stock 18 inch wheels with ONLY the stock 2 inch factory lift. I wanna know if this subtle difference can be done with no rubbing and no trimming, cutting, or having to lift further.
Thanks
Not really a subtle difference.
You're adding over 2in in diameter and a bit more width.
Thanks
Yeah definitely not subtle. Width isn't the problem - that's a pretty big increase in diameter, and you will have to at least remove the mudflap brackets. But if you do that, you can probably get away with the factory lift and possibly need to do minor trimming.
Good luck! A lot of factors as mentioned above. Watch the offset video floating around on here. Might need to do a wheel spacer as well.
Thanks
I am running 285/75 but with a 2” Ready Lift kit. 2022 model. Still have a slight tire rub on a hard turn. You’re adding almost 3” in tire height. You will need the lift unless you change rims or use a wheel spacer.
