Looking to fit 35” tires
Ae87t
I upgraded to 20in rims
Will a 2” level in the front allow me the room to fit 35in tires?
looking for the larger tires but don’t want to dump a ton of money into a 4 or 6” lift that I can’t even fit into the garage
thanks guys
thanks guys
I have 295/70/18 (34.5-inch) tires on my stock Trail Boss. You can trim the mud flaps a little and then there’s absolutely no rubbing. Looks the same as 35-inch tires but just a little thinner.
I took a good look behind the fender liners this morning and I think I can clear 35x12.5r18 on my factory wheels with BORA spacers. I might have to trim the plastic bracket behind the liner in front of the front tires, but it looks like it’ll work.
The spacers actually make clearance worse when turning to full lock. The bigger offset pushes the tire out which digs it further into the fender liner when turning the wheel. I discovered it after adding 1.5in spacers. Easy to modify the inner liner for clearance.
