Mud flap delete?
Bear76
SoDak
Only running 265/70 and I’m rubbing!!
Any good mudflap delete kits out there?
sure is, anything further south than your location... every few miles or so...the deletes will get bigger.
McGaughy's
Rough Country
I have the McGaughy's kit on my truck. Easy install. No issues. Others have said the same about Rough Country. It's just a matter of how much you want to spend.
For your situation I recommend warmer air.
McGaughy's
Rough Country
I just put on the RC mud flap delet kit today.
I have these color matched plugs, they fit the front fine but for the rear you just have to lightly file the tabs to fit. But they look clean like a parking sensor tab.
35/12.50 BFG’s replaced those nitto 295’s … delete kit helps clean up the wheel wells
because I'm cheap... 🤙
That TB looks awesome. did you alter the stance?
those rims look like they have a wider stance?
Two inch readylift SST with upper control arms, Bilstiens 5100 all four corners, 18x9 ICON Compressions zero offset , BFG 35x12.50’s…(with matching full size spare)...zero issues, Rough Country 12K hidden winch ….Leer topper …. Other mods like cold air intake, exhaust nothing crazy ..oh and that RC mud flap delete helps with clearances… no wheel spacers the zero offset is what gives the tire / wheel stance
