MY 37's FIT!!!
krazyk21
illinois
2021 Chevy Silverado LT Trail Boss
I will definitely get better pictures after work. It was dark last night. But falken wlidpeak a/t 37x12.5x18 fit my trail boss with a 6inch RC lift, 2inch wheel spacers, and stock wheels.
I have not removed anything yet.
Tires rub mud flaps going backwards turning all the way to stops. I will be taking mud flaps off.
They barley clear the front bumper but the front of the tire does not rub on anything.
I will be cutting some of the bottom part of bumper. just to re insure myself it won't hit.
Driving normal, it never rubbed.
I feel some weight off the line but nothing that seems to be worrying. Sport mode helps with this. I also have the pulsar lt programmer. Throttle response is set to 4.
Like it. I have a six inch and 1.5" wheel spacers on 18's. I was going to go with 37's. However with no rubbing at all with 35's I decided to stay with true 35's. If they made a decent 36" tire I probably would have went with those with the extra 0.5" a side. I'll consider it next time.
I believe spec says it's actually a 36.6 but I'm still happy with them. 😆
I tend to swap tires at 10K miles or less so could be before hunting season in the fall. I will definitely consider them seeing they would probably only rub full turn.
Looks way better than the itty bitty stocks before!
Nice … maybe once my 35’s need replacing I would consider 37’s , just a sweet look … maybe a regear to save tranny….. congrats looks badass bro… mine is very daily driven so wanted a low center of gravity with larger tires and 35’s works …
I suck at pictures but here you go. I needed to remove the mudguard bracket (4 bolts) and zip tie the liner back. I'll figure out something cleaner later. I had to cut the front liner a little. I get no rub on full turn to stops.
I think I'm going to cut my mudguard to be able to mount just the piece that sticks on the side. I need that color back up front. lol
Sweet , what your lift again … factory wheels so your running spacers …
it looks better without the color...but i digress
when i pulled my liners, i used thin strips of sheet metal to make brackets mounted off the bumper bolts. drilled them and used factory style push tress to hold the liners.
