OEM fogs installed on custom TB
Jlorenzo125
Texas
Wrangler TJ
Installed my OEM fogs and of course had to get em flashed at the stealership. Turned out great.
Nice Job, Looks good
I added OEM style fog lights and installed using a Gen5Diy wiring harness linked to headlights. Did not require flashing from dealership, the wiring harness turns on the fog lamps w/ headlights as the default setting. Also replaced halogen headlights and high beams w/ Sealight LED kit, super easy to swap, pretty much plug and play. Nice white beam running at night.
How was the install? Looking at doing for mine as well. Also what the stealer hit you for to flash the computer?
