Off Road Lights
Shawn_AZ
Flagstaff, Arizona
2024 Chevrolet LT Trail Boss, Duramax
2021 Chevrolet LT Trail Boss, 6.2
Greetings, I noticed the 2024 TB has a little more room in the front grille area and was wondering if anyone knew if it would be possible to run some off-road light pods in this area. Or if I should abandon this thought.
Thank you in advance.
Never abandon your thoughts it gets lonely without them! I have a pre-refresh but assuming the area you have circled is designed for the aero air curtain for reducing drag, increased fuel economy ect. I don’t know how much room is behind that area or how easy the access. Doubt aftermarket would place something there so modification of the plastic grill screen as well as brackets for mounting the actual lights would be needed.
With the right ingenuity it could be done and would be something like the 19-22 sierras which have the OEM fog lights in a similar location.
Awesome! Thank you.
Yeah, I figured some modification would be necessary and will move forward with this thought.
Thanks again, I very much appreciate it.
That looks like a fantastic area for Baja Designs S1 or S2 lights
