P1005 code
JD319
Phoenix. AZ
2019 Chevy Silverado Trail Boss Custom
1973 chevy CK10
Has anyone here had P1005 come up,
  • Manifold tunning valve harness open or shorted
  • Manifold tunning valve circuit poor electrical connection
has anyone ran into this. Other than take in to the dealer, can anyone point me in the right direction as where the loose connection might be?
Any updates with this...?
Just got this code....now my infotainment screen/center is totally f'ed up.....no music most of the time
Did you replace this part yourself?
I have not had this issue. Just doing some searching for the P1005 code for this thread. Figured if two people have had this same code it had to be out there somewhere.
I think I ran across the original pit 5636 over at gmtrucks, didn’t seem like in 18/19 they had a solution, just cleared the code. Eventually ran across updated pit5636b with hopefully your solution 🤞🏼
Okay. Thanks for the update. Have a local mechanic setup to take a look, but not until Dec. 1st.
Actually, I don't see 2019 LT trailboss on that list in the report....come to.think of it my code set was p1006, not p1005.....
