Problem with LasFit LED turn signal
crice2425
Ky
2022 Chevy LT Trail Boss 5.3 Satin Steel Metallic
Anyone else have a problem with the Lasfit LED replacement turnsignal lamps? My driver side headlight throws a turn signal fault when the turn signal has been on for certain period of time. It doesnt do it all the time mostly when its warmer out. And its only the driver side. Anyone have any alternatives to the LasFit brand?
I have found that our trucks are VERY sensitive to voltage drops on the LED lighting system. If the bulb is drawing even slightly too much power it will trigger the DIC fault.
Happens to me if I’m sitting at a light waiting to turn for an extended period of time. I don’t know exactly how long, but there is one traffic light that I turn left at that if times wrong, I have to sit through 3 light cycles. I’m guessing it has something to do with the light getting too hot.
Same problem here but only if I leave my signal on for a bit
Yes it’s only when my turn signal is on for a little time
Faulty bulb maybe. When I first got mine, one side did the hyper flash and the other didn’t.
You will need to wire in a load equalizer... LED bulbs draw so little power that the truck thinks the bulb is burned out. The equalizer is just a resister that uses up the extra electricity to trick the computer into working properly. Sylvania makes them.
7
