Rear Backup Lights
BC_Hunter
BC
Chevy Trailboss
So after owning my TB for over 4 months now, I can say that the rear backup lights absolutely suck. I recently installed a pair of LED lights off of Amazon and difference is amazing. A 5 minute job and about about $15 to improve the situation.
A good LED is night and day....the higher trims come with them from the OE...
My denali was way brighter in the camera....
Just swapped my work trucks as well.
What type
Brand and model lights did you search for?
I ordered a set of "LASFIT 921 LED Bulb Reverse Lights 912 T15 Back Up Light CANBUS Error Free W16W 906 Reversing Bulb 904 916 6000K Xenon White New Upgrade Design(Pack of 2)" from Amazon, they should work.
Also ordered a set of 194 LEDs for the license plate bulb replacements. Figured might as well make it easier for the COPS to read my plate....:ROFLMAO:
What is the part number for the reverse lights? When I put what I think should be the number in Amazon it says it will not fit a 2024 trailboss… dunno
Straight from lasfit, by far one of the most useful mods I’ve done.
What is the model from Amazon you purchased? Can you send model #?
Thanks
https://www.amazon.com/dp/B081YJ7G81?ref=ppx_yo2ov_dt_b_fed_asin_title&tag=trailboss00-20&th=1
Per Amazon these will not fit my 2025...however it is a 921 bulb size and all I can find states that is the size needed. Mine are sitting on the counter and I will install (or attempt to install) in the next few days; depending upon the weather and left foot.
Amazon proven wrong again. These Lasfits fit perfectly and are brighter than a star. In other words a hell of a lot brighter than the incandescents in the garbage can,
Not the first time Amazon has stated something won't fit; same with Walmart, they insist Mobil 1 Dexos D is not the correct oil for my 3.0L diesel.
Thanks
***Please note that it says it doesn't fit but it does***​
LUYED 912 921 LED Bulbs Reverse Lights Xenon White 2200 Lumens Extremely Bright Canbus Error Free W16W T15 906 3030 20-EX Chipsets with Lens for Backup Lights, Pack of 2​
Visit the LUYED Store
Reactions: CF_
I've performed the same mods you have done, no issues at all. I purchased my Sylvania bulbs at O'Reilly Auto. Much better for backing up and for the local police/sheriff.
Thanks for the info I ordered both sets today, (license plate and reverse lights), from the Amazon link posted here
It surprises me that chevy would use incandescent bulbs for the tag markers
I went with the Auxito reverse lights. Never had Lasfit, so i can't make a comparison. But the Auxito's have been great. Super bright and zero glare in the back up camera
Auxito Reverse Lights
