Redarc Tow-Pro Liberty Brake Controller 2023 TB 5.3 LT
23TBinSC
South Carolina
2023 Trail Boss, 5.3L, LT
2020 Jeep Wrangler
2023 TB 5.3L, LT
Has anyone installed the Redarc Tow-Pro Liberty Brake Controller? If so, are you happy with it and where did you install the control knob?
Can’t comment on the brand of brake controller but I would install the knob in the factory location using the blank plate that’s already there.
Assuming you have a blank plate in factory location if you are adding that feature.
Thanks for the input PistolsFiring. On the 23's there is no blank. If the truck did not come with a controller, they put the autostart/stop in the area you highlighted. I do have a couple places in mind to mount the knob that should work out fine. I will post pictures once I have it installed.
Gotcha. Mines a 22 LTD with no brake controller and there is just a blank plate in the factory location. Obviously they didn’t do that in the refresh interior!
