Remote Removed From Vehicle Horn Honk
JustJohn8511
Jacksonville, NC
2021 LT Trail Boss 6.2
USMC 1991-2021
Hello all. I have a 2021 LT, and the manual states that I can disable the "Remote removed from vehicle" horn honking notification, but when I go into the settings on the touchscreen, it's not there. The "remote left in vehicle" notification is there for me to edit/disable, but not the removed from vehicle one. Any ideas?
As a hunter, this is a bit of a problem on early mornings in the woods. I need to be able to get out of the truck to unlock gates, etc. with the engine running. Thanks for any guidance.
-John
I read through a LOT of the manual for my Corvette, because it has Keyless Access features similar to what you describe. (My Custom level TB does not.) Unfortunately, while it is easy to use the DIC in my Corvette to turn off the Horn honking when I get out, and the car locks, you have probably already tried that. And I couldn't find anything else regarding this issue.
I have a 2020 TB, no idea if it's the same as 2021. Turning off the "key left in vehicle", solved this issue for me. Give it a try.
Sorry, "Remote left in vehicle".
Seems the Remote Left in Vehicle solved it for me.
Remote into the gas station with you? Maybe the distance the remote traveled away from the truck triggered it? You have same settings as me. I'll try distance with mine
Yea, keys stay in my pocket. Once I have my first oil change done, I will have them update the software also. Maybe that will fix it.
I did the gas station trip today. Got about 40 yards from truck. No honking on return. Good luck. Let us know when you figure it out.
Thanks guys. I'll try turning off the "remote left in vehicle." I currently have it set to lights only (no horn) and, now that you mention this, I have not noticed the horn honk on exiting the running vehicle either...possible connection? More to follow. Thanks for the help guys!
Well, turning off the "remote left in vehicle" option seems to have also turned off the "remote removed from vehicle" honking. I've tested it out twice, getting out, closing the door, with the engine running, and no honking. I walked at least as far away as I have in the past, but the honking curse seems to be lifted. This feels like a win!
