Hi folks, hope this is the right forum place...I am trying to find the best/safest point on the frame to jack up the front (and back) of the truck using my pump hydraulic jack. I read the owner's manual, but it only refers to lift either left or right sides for changing a flat tire. I am trying to lift the entire front to do tire swapping or fluid film spraying with wheels off. Same question for the rear: does not look like you can use the differential housing because of the drain plug in the center. Looks like I need two jacks? Thanks in advance.
