Slightly Bigger Tires
Chasepig
Ft Worth
2026 LT Trail Boss
Just purchased at 2026 LT trail boss with 275/60/R20 tires. Want to go slightly bigger with just 275/65/R20 tires. Was wondering if anyone else has gotten away with this with little to no rubbing?
They rubbed, requiring minor adjustments to the frame bracket and the plastic bracket that holds the front of the wheel well liner.
Did they rub bad or just slightly at full turn?
Front rubbed lightly with wheel turn, rear when going in reverse even with wheel straight. To be honest it doesn’t take much to make them fit without rubbing.
You got a pic of yours by chance?
And thanks for the help
I took a quick visual (on my 20" rims) and yea, wow, the rear has lots of fore/aft clearance, but the distance from the shoulder of the tire to the springs is limiting. I can see it rubbing if you go to a 12.5 wide tires. Those 20" OEM rims must have some negative offset or something.
Yeah according to CGPT, they come factory with +26 or +28 offset. Negative offset would be better because they would stick out from the wheel well further if I remember correctly. I put a level on my last truck and went with 0 offset and was able to go bigger no problem. Didn’t really want to get new wheels for this truck anytime soon…
This was early last year with the fresh tires before I (gasp) lowered it, so stock suspension.
