DForm
- Joined
- Jul 30, 2022
- Messages
- 74
- Media
- 1
- Reaction score
- 25
- Location
- East Greenwich,RI 02818
- Current Ride
- 2022 Trail Boss LT
Has anyone drilled any holes in the front corners of the bed for tonneau cover drainage tubes ?
Thanks- I’ve see these holes and I’ve also seen a dealers video where he states he’s put them off to the sides for two reasons . One if you put them in the holes that are there they maybe in the way when loading material, and second if you drill holes in the forward side there’s vents for reliving cab pressure and you don’t want to be drawing water into them. And I also thought that if you do get water in the bed how will that water drain if the holes are used for the tonneau drain lines.Mine were there already as well.
