I purchased the Whipple tune, it has new MAF, new plugs, new upstream O2s.. smoke tested for vac leaks twice, found nothing, long term fuel numbers hang between +4 and +6.. No codes…. I had HP send me a spare stock ECU , and no difference. I even took the blower off this past weekend, put it back to stock, re uploaded stock tune and it does the same darn thing in stock formation… had I not seen it on the data log, the average person probably wouldn’t be able to pick up on the miss..
As soon as I go above roughly 20% throttle, miss clears out.. as soon as you power brake it, miss clears out.. it can idle all day long and not miss. I’ve plugged up evap purge incase that was opening, no change.. I’ve compared both the 3Bar and 4bar MAP values both with blower and without, and there are no spikes, I’ve watched TPS during the miss, no spike in value.. I’ve swapped 3 different style plugs, blower plugs and factory, no change, new set of Texas speed wires, no change…all of which Whipple tech told me to replace and myself darn well knowing it wasn’t gonna fix anything.
Also found out from Hp tuners, that now with the ECU unlocked, it can no longer be calibrated using GM tools, so I would have to purchase brand new ECU and have it programmed…No lifter noise, fresh oil change when I put blower on, and did it again 2 days ago, running mobile1 0w-20 and Wix filter. Both whipple and Hp have no further suggestions. I’m afraid it’s internal but not really sure what mechanically would cause a miss at such a light throttle load between 1100-1700rpm. I have yet to learn about the timing advancement with this motor, I wonder if cam actuator (if equipped) is floating the timing during that range.. definitely a head scratcher but I really appreciate your response. I wanted to run it this weekend with both crank case breathers plugged to see if it changes the numbers. Otherwise in order to take it back to dealer, I would have to purchase and program a brand new ECU. Thanks again for your time.
