*update* bilstein 6112 and rear 5160s
Twotrac
Michigan
2020 TB
2015 f350
I’ve done some digging, does anyone have the 6112s set at the clip for 1.2 inches of lift? I’ve changed my route on build and am now going to do 6112s with 5160s out back, for rims and tires I’m going with 315/70r17s on method mr 703s with a zero offset. I’ll be doing dirt king ball joint upper control arms. Anyone running something similar?
I have the same components, although I have 20x10 -18 with 35x12.5 Baja Boss AT. Due to the aggressive offset, I also added a 1/2 bottom spacer and the truck is perfectly level and no rub (I still had to trim the mudflap and tied the liner back).
One note about the DK UCAs, if you get the dirt caps they were a bitch to get on due to the supplied o-ring which seems to be too thick. I had to sand the rubber ring down to remove some material so they would go on without an insane amount of force.
I’ll be doing the 6112/5100 setup after my Ranchos wear out… I’m thinking 1.2in paired with the new cast iron Zone arms.
Do you have any pictures of your setup? I was considering tossing a half inch spacer below if need be but think I can make them fit with zero offset wheels. Thanks, I was wondering how those caps attached and kind of assumed it was a rubber ring.
Hello. I did the zone upper control arms with factory 18 wheels with nitto ridge grappler 295/ 70/18. Sorry truck is dirty. I like the way it looks. Still works on 4 auto. Looks awesome. Here are some pictures.
Any Side shots of it!!??? You’re keeping me on my toes here haha.
No pictures yet and I’m currently overseas.
I think I’ve been reconvinced to run the fox 2.5s with dsc and dirt king uppers. Also I’d be running 3/8 or 1/2 inch spacers if I kept my factory wheels. Here’s the part numbers for extended studs to achieve more thread purchase.
I see no part numbers. What are they?
Here’s a link, I’m going to run these or the ADS 2.5s which are similar to the fox’s. I run the dunes at silver lake a good amount and want some substantial performance improvements in the suspension department. I watched a tundra yesterday with a nice mid travel kit ripping around and I had my questions answered.
