Update FIXED - 2022 refresh radio intermittent audio for the first 2 mins of driving?
Crash699
Vancouver
2022 LT Trail Boss
I just had my truck into the dealer for the latest software for the radio and wireless charger issues.
The charger is working fine now but the radio still drops audio for the first 2 minutes of starting vehicle.
I only listen to FM for the most part and it seems to drop audio for a second then comes back on but it will do it 2-4 times every key cycle.
Today, it now drops audio completely and will only come back on if I change the channel and go back to the station I was listening too.
Sooo frustrating to say the least. Has anyone had success at having this issue fixed yet?
Common issue, no fix yet but GM knows about it. The cause seems to be all the services starting up competing for CPU cycles which causes things like the radio to drop out. Supposedly this issue is something that Google is supposed to fix but was stated they won’t be able to address till end of ‘23 or early ‘24. Happens no matter what source it is, FM, Sirius, Android Auto, CarPlay, etc…
Thanks for the info!
Let’s hope google actually follows thru!
I have had that happen several times but usually when I'm connected with CarPlay
I have also had the same problem. It has something to do with the Android Audio connection. Havent spoken with the dealer yet, but I will at my first visit.
Mine has done this since I purchased. Been to dealer several times and never fixed. So frustrating.
Mine has also dropped off with no audio. I found if you go to settings and do a reset or do a soft reboot it corrects the problem.
UPDATE
I went Friday to have a new software update done for the radio issue.
Fingers crossed it fixed my issue of the audio dropping out.
I have been driving it all weekend and today with out an issue.
It would always drop out on EVERY key cycle….now on multiple starts,
the radio works as it should.
What was your wireless charger issue? would it be that it connects and starts charging then just stops? Mine is doing that from new just waiting on an appointment to have it looked at.
Pretty much. No case cover on the phone it would charge ( not very fast) then stop.
It would also drain the phone battery more than charging it. The first dealer was going to replace the whole wireless charge Assembly. I took the truck to another dealer and the tech reprogrammed it with the latest software and it has worked fine since.
The reprogramming of these vehicles seems like a problem for gm. There are 2 ways to program. (Wireless or usb) usb it the ONLY way that seems to work. Even though, it can still crash during the reprogram procedure.
Chiming in on this as it's become a real aggravation to me. I bought my TB new in July of 2022 - after the first reprogram from Chevy the sound cutting out began. I've had it back 4 times for programming and a radio replacement nothing has fixed it and recently it appears to have gotten worse or more frequent. Today I dropped it off and asked them to contact GM regional support and I don't want it back until it's fixed. I don't have a lot of faith in getting it corrected and I really hate that because I absolutely love my TB.
Was the dealer able to get it fixed? My '22 refresh did this until the software update earlier this year and now it's back with a vengeance!
This is still on ongoing issue!
The truck has been back several times for the same audio drop out problem. Almost everytime, there's a software update! Going to book it in again to see if anymore updates.
I stopped into my local dealership this morning to check on a fix, and as we all know, there isn't one. GM has called this a 'software anomaly.'
