295 70 18 Baja Boss with RL 1.75 Leveling Kit
Not sure if you are running stock wheels , mine are 18x8.5 .. have the Falken RT in the 295x70x18 .. put a 1” spacer on and had maybe 1/8” clearance. I ran the Micky’s before swapping them out when needed new .. think the Micky’s are just a bit wider across the tread.. you for sure will need to trim
Yes I am running the stock 18's. Do you think the extra half inch spacer i have would hinder clearance or give me even more room? Not sure if spacers in general are a good or bad thing when worried about fender well clearance.
The 1.5” spacers will cause you to require more trimming ..tire will hit sooner as you turn
I can attest to the above being true
Im running the 2 + 2 RL sst lift, 1.5" spacer on stock 18s with 285/75r18 duratracs. Just put on. I have full clearance and no rub on anything but mud guard at +90% turn in reverse.
The truck has imo an amazing stance now and nearly perfect height without going to a big lift.
Itll have to do for me for now, but maybe around 160-200kms, Ill upgrade to the 4 inch big lift and throw some nicer 20s on her.
Ive trimmed the mud guards as much as I want for these almost 35s. No rub on RL uca at all, not even close.
