Drive Modes
Creekbum
Tidewater Virginia
2026 Silverado LT 1500 Trail Boss
2023 Camaro 2SS
US Navy (Retired).
My 2026 1500 LT TB has normal, sport and off road modes selectable with the dash knob. But not snow/ice mode or terrain mode as described in the owners manual. Am I missing something?
Hmmmm? If you find something that says you have those options in your rig, let me know because that means I should have that as well in my 2025.
i have always been curious, what they all should actually have....
my 23, does not have Sport mode...it has the offroad and normal (i will play with it again this weekend to confirm), and i think Ice and Snow.
I looked it up via AI. Here is what I found for my specific LT model:
Let’s map every drive mode you actually have on your 2025 Chevrolet Silverado 1500 LT Trail Boss and—more importantly—exactly where to find and activate each one without guessing.
🧭 First—Know Your Two Control Areas​
1) Drive Mode Selector (rotary knob)
  • Usually center console or lower dash
  • This cycles your main modes
2) 4WD Selector Panel (left of steering wheel)
  • Buttons: 2HI / AUTO (if equipped) / 4HI / 4LO
  • Enables certain modes (like Terrain)
🚗 ALL YOUR MODES + EXACT HOW-TO​
🔹 1. Normal Mode (Default)​
What it is: Everyday driving balance
How to activate:​
  • Start the truck → it defaults to Normal
  • OR turn the Drive Mode knob until “Normal” shows in the cluster
📍 Location:
  • Drive Mode knob
🔹 2. Sport Mode​
What it does:
  • Sharper throttle
  • Holds gears longer
  • More aggressive feel
How to activate:​
  1. Turn the Drive Mode knob
  2. Stop when “Sport” appears on dash
📍 Location:
  • Same rotary knob
🔹 3. Tow/Haul Mode​
What it does:
  • Engine braking
  • Better for towing/loads
How to activate:​
Two possible ways (depends on your setup):
👉 Most common on your truck:
  • Press the Tow/Haul button at the end of the shifter stalk
👉 Or via knob:
  • Turn Drive Mode knob → Tow/Haul
📍 Location:
  • End of column shifter OR knob
🔹 4. Off-Road Mode​
What it does:
  • Adjusts traction control
  • Better for dirt, gravel, light trails
How to activate:​
  2. Select “Off-Road”
📍 Location:
  • Drive Mode knob
🔹 5. Terrain Mode (Special Case)​
What it does:
  • Crawl control (one-pedal feel)
  • Max traction at low speed
How to activate (recap):​
  1. Stop truck
  2. Shift → Neutral
  3. Select → 4LO (left dash panel)
  4. Shift → Drive
  5. Press Terrain Mode button (below 4WD controls)
📍 Location:
  • Button under 4WD panel
🔹 6. 4WD Modes (Not “drive modes” but critical)​
These are just as important:
2HI​
  • Normal dry driving
AUTO (if equipped)​
  • Automatically engages front wheels when slipping
4HI​
  • Snow, rain, slippery roads
4LO​
  • Required for Terrain Mode / crawling
📍 Location:
  • Left of steering wheel
🧠 How to “Find Everything” Quickly (Simple Walkthrough)​
Sit in your truck and do this:
Step 1:​
Look left of steering wheel
  • Find 4WD buttons
  • Look directly below → Terrain button
Step 2:​
Look center/lower dash or console
  • Find the rotary knob
  • Turn it slowly → watch dash change:
    • Normal → Sport → Off-Road → Tow/Haul
Step 3:​
Check your shifter
  • Button on the end = Tow/Haul shortcut
⚠️ Important Reality Check​
  • You do NOT have Snow/Ice mode (common confusion)
  • Your truck replaces it with:
    • 4HI
    • Off-Road mode
    • Driver control
🧊 Real-World Usage Cheat Sheet​
  • Dry roads → 2HI + Normal
  • Rain → AUTO or 2HI
  • Snow → 4HI
  • Dirt roads → Off-Road
  • Deep snow / stuck → 4LO + Terrain
I'm guessing this is an option on the LT trucks? I don't recall seeing drive modes available on my custom level.
Yes, you are correct. I had a 2022 Custom TB that turned out to be a Lemon. It did not have the drive modes. The LT has the Off-road and Sport and in 4LO the Terrain.
well, lets start the list and see why...
23 LT2 6.2L 10 spd
Normal, Offroad, Tow Haul
(will confirm the Ice and Snow)
is it possible, certain years, Trans or engine are related....
I can speak for my last truck.
2022 LT LTD (pre-refresh) 5.3L 10 spd
Normal, Offroad, Tow-Haul
My LT Trail Boss Refresh does not have Sport.
Hmmmm? I wonder why? I thought all LT [refreshed 2022.5 and later] TBs have the Normal, Off-road, and Sport modes.
Sport and off road mode also changes the active exhaust to fully open. I think this is on 25 and up. Noticeable difference in exhaust note. Do a cold start in each and you will hear the difference. I drive in sport all the time in the city, normal on long highway trips. I have a pedal monster for throttle repsonse so can't verify the throttle mapping. Generally makes sense.
i fully believe this was a result of the issue related to the virus...far to many variations during that time frame...
i also run a pedal monster, as it didnt have a sport mode. Typically shifting manually with 8 or 9 being highest gear used....and tow/haul engaged in most cases too.
since the introduction of the GM 6 speeds, tow/haul has always been my preferred STOCK shift schedule...until i have time to tune the trans to my liking.
What motor do you have? I have sport mode on the 3MAX (which kinda does not make sense ;)). I wonder if the 2.7 L3B's do not have it? They have the 8-spd tranny too (I think).
