Effects of 87 octane
What do you think, is this relevant for the 5.3 engine or only for the 6.2 ?
as with any engine, the DESIGN of the components...meaning...Comp ratio, cam selection, ignition timing and even the material types used all can have an effect of what octane is NEEDED, the 5.3 is designed around the lower octanes...until you introduce HIGH HEAT TEMPS, that is when GM recommends the use of higher octanes. the 6.2 is already a higher compression and therefore by design, GM recommends the premium levels of 91 or higher.
an engine only NEEDS the octane it NEEDS, higher octanes dont always make more power....that is not what octane ratings are for.
i can say i have tried all octanes just to see, i have never done this is high heat temps, nor during a loaded down drive....what i have noticed mostly, is the mileage per gallon tanked with the lower octane fuels. i mainly use my truck to commute from Louisiana to Missouri (800 ish miles), with each passing tank, the distance to empty would drop during each fill up with lower octane fuels. on the return drives...it would climb back up as each fill up was restored with a higher octane. my truck has 36K as we speak....90% of those are these trips. otherwise, she sits in storage.
Like I said before If you can afford a Sixty Thousand dollar truck you can afford premium fuel. (93 octane) I have 25000 miles on my 2022 LTD 6.2 Trailboss and started using premium after I emptied the 1st tank from the dealer fillup. Just my choice because I plan on keeping it for awhile.
I wish I could have paid sixty for it.
below is a snip it dating back to the 2016 Silverado manual....
For all vehicles except those with
the 6.2L V8 engine, use regular
unleaded gasoline meeting ASTM
specification D4814 with a posted
octane rating of 87 or higher. Do not
use gasoline with an octane rating
below 87, as it may cause engine
damage and will lower fuel
economy.
If the vehicle has the 6.2L V8 engine
(VIN Code J), use premium
octane rating of 91 or higher.
Regular unleaded gasoline rated at
87 octane or higher can be used,
but acceleration and fuel economy
will be reduced, and an audible
knocking noise may be heard. If this
occurs, use a gasoline rated at
91 octane or higher as soon as
possible. Otherwise, the engine
could be damaged. If heavy
knocking is heard when using
gasoline with a 91 octane rating or
higher, the engine needs service.
