GETGONE
Well-known member
Lake Speed Jr posted this video of a crankshaft he got from Dave's Auto of an L87 that failed the pico test but the engine hadn't failed yet. Dave had found wave wear patterns on the crank bearings. It was sent out and it was measured to have waves on the crank bearing journals. The REAL ROOT cause of the engine failures! Dave had posted he things part of the failure is due to the variable oil pump that lets oil pressure get too low at idle and low cruising RPM. He is talking about a fix but it requires unlocking the ECM and TCM via HP Tuners then making some updates to the variable oil pressure mapping to prevent pressure from dropping too low and damaging the bearings. Not sure if his video was before they confirmed the waviness of the crank or not.
