ChrisK
So I just bought a 2026 trail boss and I'm wanting to get it lifted 2 more inches. Can someone give me a rough idea of how much $ I'm looking at for the lift kit and install? TIA
Sounds like I'm leaving it as is lol. Thanks.I did not do this to my Silverado but have built jeeps in the way-back. You didn't specify if you want to do it cheap, or you want to do it right. On the cheap side using a 2" level up front, new UCAs and rear blocks you are probably looking at $1500-2000 for parts and to have them installed. To do it right would require UCAs, front/rear springs, shocks, longer brake lines and possibly longer drive shaft(s) which would likely be more in the $5k range.
Additionally either way you are likely looking for larger tires?, add an additional $1500-2000. Depending on how large, you may also want to have the 3:23 gears swapped out to something larger.
Doing anything will likely void your warranty on [minimally] suspension components.
good luck to ya.
