Muffler delete
The rear clamp is a lap joint one I had laying around that I had tried to use elsewhere before. The Magnaflow clamp it came with wouldn't tighten down enough. The 6.2's only have the rear flapper.
Wouldn't tighten down enough? Sounds like poor quality parts
It needed to be a bit smaller. The clamp bolt bottomed out and wasn't close to tight. It may be because of how I cut the pipe to eliminate the rear flapper which it wasn't designed to do.
Yea I'm looking for a muffler delete pipe that's designed to remove both flappers.
Ehh. I decided to just go with Afe muffler delete pipe... I was under impression I had 2 flappers. I only have the one. 100 bucks. Will post some pics when I get it.
