Ready lift
So what did the billisteins do for you? Did you adjust them to make it higher?
Left them at zero setting getting additional 2 inches of lift from the ready lift … no more bouncy feel… it rebounds quicker … no side to side wobble anymore … feels very planted to the ground…
So you are at the same height as you were before adding the bilsteins? I guess you wouldn't be able to adjust them any higher because of cv angles right?
Correct I would have been ok if the Bilstiens were not height adjustable … I just wanted the nicer control and ride … and the new upper control arms with the slight lift that the ready lift provides …not a fan of the factory ranchos … they are not the same as aftermarket ranchos …
Got ya. I came from an 06 2500 so this thing rides like a Lincoln to me
Yes the factory ranchos have a “luxury “ car ride ….
Ready lift 2.0 sst for about 3 months now… I was so very hesitant on getting it installed,. over thinking the whole cv axle angles talk … but went forward with it since it was made specifically for the trail boss and I did up grade to Bilstiens 5100’s … wow I’m so happy with the the ride and stance now …I’ve had my TB since new 2020…
What is the camper you have on it?
Do you have the taller rear block installed? Looks level with no rake is why I ask. Wondering how much the bilsteins and extra weight from the leer have?
Yes I had the the entire ready lift 2.0 installed including rear blocks … I do have a winch up front so that may be offsetting the weight a bit in the rear from the camper shell … but it does sit level due to the extra weight of the leer camper .
