That’s the wrong front gear set for a 19+. That’s for a 14-18 only. Our trucks have an 8” front ring gear. There is a 4.10 ratio available, but who knows who makes it.
First, you’ll need to know if you have the GM SU5 or AAM SU4 front axle. The AAM has the gearing options. Check your rpo codes or look at the cover and compare to this video at 0:14.
This is the 4:10 gear setup. I guess you could call this shop and see if they’ll sell you the carrier snd gear setup.
The rear AAM stuff is the same as a 14-18 9.5 12bolt. They have a carrier split at 3.23/3.42. The old 9.5 14 bolt carriers are the same as the 3.23 and down 9.5 12b. The 9.76 12b gear sets have a larger inner pinion bearing and won’t work in our 9.5 housing. The 9.5 14b gear sets have a different pinion spline count.
I just put a yukon duragrip in my truck this weekend. I’m sticking with 3.23 and 35’s. But my truck has a magnuson blower. A 3.73 or 4.10 and a 35 is going to have a high driveshaft speed at interstate speed and may be too high for the OE aluminum driveshafts critical speed.
