Regearing Axle Ratio from 3.23 to 4.11 or 4.56? Any thoughts???
Here was my Sundays...WHY NOT project. this is the only piece i had left to touch on the 89.
why ??? no reason, wasnt broke, just a one wheel peeler.
decided that day was the day to do something better...now, does it snoball into a stronger, bigger diff or housing...most likely.
but a simple regear and lsd is al it needs...maybe lager shafts to ensure the 420/420 doesnt kill it...but it has survived that since 17, and been there since 89. but you get the point...
I have changed multiple rear gear diffs on older trucks. Your gas mileage will be affected. You will regain your power/torque at low speeds, but high speed acceleration will diminish. Also, i have found that changing the gear ratio along with upsizing tires changes your speedometer reading. Your truck will say you are going 60, but in reality you are going 66 (just an example).
I have done so much work on my truck up to this point costing thousands (~$40,000) so I am somewhat indecisive regarding a decision to regear. I may just keep the 3.23 ratio considering my off-roading really is not too high of a percentage. I guess if I off-roaded more than say, my current 20-25% of the year, a decision to go up in gears may come more of an easy answer for me. My main reason I wanted to go up from a 3.23 to 4.11 or even 4.56 was based on the larger tires and the additional weight I have been adding. I wanted my rig to run within the RPM powerband consistently and just feel more "alive" per se. But, since I do not off-road too often, I am not set on tearing my 3.23 gears out and replacing with a different set and forking out mucho dinero.
HOWEVER (Haha!), AI gave me the following advice!
Given your exact setup, this is a good question—and there is a clearly better choice between 4.11 and 4.56 for how you actually use the truck.
Your current relevant setup (important)​
  • 2025 Silverado 1500 LT Trail Boss
  • 5.3L gas
  • 10-speed automatic
  • ~34.8" tires (305/70R18)
  • Lifted, off-road use
  • Not a heavy/constant towing build
  • Current gears: 3.23
First: why 3.23 is wrong for your setup​
With ~35" tires:
  • Effective ratio drops to ~2.95
  • Causes:
    • Sluggish throttle
    • Constant gear hunting
    • Poor crawl control off-road
    • Higher transmission temps
    • Engine lugging at low RPM
So regearing is absolutely justified for you.
4.11 vs 4.56 — real-world comparison​
🔧 4.11 Gears​
Pros
  • Closest to restoring factory drivability
  • Slightly better highway MPG
  • Lower cruise RPM
Cons
  • Still feels a little lazy with ~35s
  • Less torque multiplication off-road
  • Transmission still works harder than ideal
Highway RPM (10th gear, ~70 mph):
  • ~1,750–1,850 RPM
👉 Good, but not optimal for your tire size and off-road use.
🔧 4.56 Gears​
Pros
  • Best match for 34.5–35" tires
  • Noticeably better throttle response
  • Stronger low-speed control off-road
  • Less gear hunting
  • Reduced transmission strain
  • Makes the 5.3 feel “lighter” and more responsive
Cons
  • Slightly higher cruise RPM
  • MPG drops ~0.5–1 mpg vs 4.11 (usually offset by less downshifting)
  • ~1,950–2,050 RPM
👉 This RPM range is right in the 5.3’s sweet spot.
Off-road & daily driving reality​
Since you:
  • Run ~35s
  • Lifted the truck
  • Do off-road driving
  • Don’t tow heavy constantly
4.56 gears are the better choice.
They restore torque, drivability, and control—not just power.
Most people who choose 4.11 with 35s later wish they went 4.56.
Almost nobody who goes 4.56 regrets it.
Transmission & longevity (important)​
The 10L80:
  • Likes lower load per gear
  • Hates lugging
  • Benefits from deeper axle gears with larger tires
4.56 actually helps transmission longevity compared to 3.23 or even 4.11 with big tires.
Final recommendation (clear answer)​
They are:
  • Correct for your tire size
  • Better for off-road
  • Better for drivability
  • Easier on the transmission
  • Still perfectly fine on the highway
Two critical notes​
  1. You MUST regear both front and rear (4WD)
  2. Speedometer & shift logic must be recalibrated after regearing
Watching…
I am 99% happy with where I have my truck now. Unfortunately, when I purchased it I thought that was the end of my journey and got the 3.23. Now that I am running 35’s on a 2” lift (Cognito Fox 2.0 + Deaver) I am wondering if regearing to 4.10 and a tune is the final piece of the puzzle. That said, as people familiar with my prior posts understand by now, I am somewhat less than capable with a wrench and concerned that opening up the axels for a regearing (and probably upgrade differentials while I am at it) is inviting more trouble than the perceived problem it solves.
I think the old 70s on back use to be 4:10 gearing as standard...use to say it in commercials while the truck was plowing a field...middle 80s i think they started changing that...and now to get mpgs we have 3:23
Th400 and TH350 transmissions had 2.48 1st gears and np203 and np205 xfer cases were 2:1. The 10L has a 4.7 1st gear and 2.70 xfer case low range. When you factor in the vastly different rearend rations snd now taller tires, it all works out to be very similar. But we have great overdrive ratios now.
Transmission tuning would probably do more to fix the “feel” of the truck. It shifts so early, that when the converter is locked you’re at 11-1400 rpm all the time. That won’t really change with gearing alone.
The camaro with a 10L trans has a 2.77 or 2.85 rearend ratio to match the shorter tire. But they’re programmed to shift at higher mph(rpm) and kinda keep the engine at a higher rpm to feel more sporty. That can be done in the truck through HP tuners.
Bring them to TN. I’ve done hundreds of sets of gears. I worked at a mustang shop in the early 2000’s while in college. I bet I did 2-3 sets of gears per week for 2 years. Since then I do stuff for local friends and a few shops.
I’ve done.
Ford: 8.8 and 9”
GM: 8.5 10bolt, 8.875” 12 bolt, 9.5 14 and 12 bolt, whatever the OBS front differential is, 9.5” V2 ctsv rear
Dana: 35, 44 and 60
Gears aren’t rocket science. You need a good press, a bearing splitter, something to measure shims with, a bearing race punch, a dial indicator for backlash and a little ingenuity for stubborn old bearings.
Buy quality gears sets, OEM when available are top. AAM, GM and Dana are available through rock auto. When they don’t have a ratio you want, East Coast Gear Supply or Rons Machining service for Yukon or motive orange label are my second choice. Lower numerical ratio gears (up to 3.73) are less finicky to get a good pattern. 4.10 and up is where it usually gets to be a little more work.
Always start with the factory pinion shim and 90% of the time that’s just right. 99% if you use an oem gear. Go for .005-.008” backlash. Tighter side on our aluminum 9.5 12 bolt since the housing will expand a little more. Since our front diff isn’t a clamshell type, it’s easy to measure backlash and pattern just like the rear.
I looked into regearing mine without any luck. Contacted a shop that does that sort of mechanical work and they told me
since my TB is equipped with RPO code SU4; the smaller 8" IFS is not suitable for regearing to 4.56 from 3.23. They said parts for that are dealer only - and due to space constraints inside the differential - it likely will never have anything deeper than 3.73 available. Uggghhhh! Basically, the front differential is extremely light duty, it is an 8" like a Tacoma, just with less space. They said if I had an 8.25" front differential, it could be done. They said they have never explored the compatibility, but if someone on here has regeared to 4.56 that has the 8" like mine and has it documented of what is needed, please let me know. Thanks.
I am running basically 35s (305/70 18) with a 6" suspension lift. I am considering regearing to a more staunch force axle ratio. Just wondering if anyone has completed this upgrade. If so, what brand for the kit did you go with, i.e., Nitro, Yukon, etc.? Any replies are welcome...I am looking for any info here to help me decide. Thanks!
Coming from 3.23s, the truck is definitely under-geared once you add a lift and larger tires, so regearing is absolutely worth it. Between 4.11 and 4.56, it really depends on how the truck is used. If it’s mostly street and highway driving with some off-road, 4.11s are a solid balance and keep RPMs reasonable while improving throttle response. If the truck is heavier or sees more off-road use, 4.56s make a noticeable difference in low-end torque, with only a small increase in highway RPM. Just make sure the speedo and transmission are tuned after the regear to get the most out of it.
I ordered the 3.73 fronts a few weeks ago and it appears they will be shipping this week. I'll document the gear swap here when I get around to it.
Thanks man!
The shop I am consulting with told me with our TB's, the deepest gear can only go to 3.73.
Hey fellas!! Any update from those that did the regear? Something like this is definitely on my future get-done list.
Good bye gas mileage on open roads. Will be great for off road though.
I regeared to 3.73’s. With 37’s, I’m basically back to the same effective ratio as the stock 33’s and 3.23’s. No regrets, the truck drives great. Mine makes ~700hp, so it’s not as comparable to a relatively stock truck, but I see no downside to it for anyone. With our trucks with the 10L80 and a .64 ratio 10th gear, 3.23 to 3.73 isn’t going to raise the rpm at highway speeds by a huge amount.
It had no effect on my gas mileage. I think that thinking comes from people who swap gears and don’t correct the speedometer. Same with changing tire size. If you correct the speedometer in either case, the change to fuel mileage is negligible. I get 17 mpg hwy (cruising mostly 80mph) and 21 mpg city.
BAD ASS, thanks for the info!! I'm rolling on 34's with a 3" lift, and when I take my foot off the brakes at stoplights, my truck does not idle forward; and thats with the 6.2 block. If/when I'm not a poor peasant, I'll seriously look into the 3.73 re-gear and the subsequent tuning as well.
As my rig sits now, I'm at/around the 17mpg combined area. I'm really not worried about MPG's, I just want this beast to act like a beast. IF this work enhances my mpg's it would just be the cherry on top.
