Road Noise on stock Goodyear Wrangler Territory MTs
DocSteve
Trojandoc1
2025 Trail Boss Custom
I have a stock '25 Custom TB 2.7 Turbo. The road noise with the stock tires (Goodyear Wrangler Territory mt lt 275 65 r18 113/1100) when driving low 50s to 60 MPH is ridiculous. The door tag recommends 41 PSI so I bumped it up to that and the noise is extreme at that speed range. I have not dripped to 38 PSI again, but can. I believe this noise is a common issue. I am hoping for a solution as I am only at 20,000 miles. I rotate them with each oil change at 7k increments.
Any thoughts or suggestions?
It only gets worse. I lasted about 36k miles before I couldn't take it anymore. Still had plenty tread left but for my sanity I had to get rid of them.
I'm starting to notice it now and I'm at just about 10k miles. But it's not bad so far. I'm interested to see how bad it really gets because I do like these tires. I'll be going to a 35 once I am done with these though and I'm sure those will have as much or more road noise than these do though.
20,000 km on mine and they're starting to hum. My last Trail Boss had Duratracs on it, so I can handle anything! 😝
Thank You. What did you replace them with? Same size? Are you happy?
I went with KO3'S in 295 65 20. With a 1.75" RL . 20x9 0 offset method wheels
