Transmission shudder
jmtaleroski
Pennsy
2026 Silverado LT trail boss
I bought my 2026 Silverado LT trail boss in May, brand new, I have 3400 miles on it. I have been experiencing vibration/shuddering, feeling of gear hunting especially when tachometer is between 1000 and 1500 RPMs, all speeds, happens when coasting, decelerating and low throttle. Heavy throttle no issues, but this is at high RPMs. Took it to the dealer, they “couldn’t find anything wrong with it”. Anyone else this ? If so, were you able to identify the problem ?
I found an informative article that may help give you ideas. I know you have a 2026, but symptoms are symptoms. https://www.gearboxinsider.com/blog/10l80-torque-converter-shudder/?utm_source=chatgpt.com
Not something I’ve had myself, but that sounds like torque converter shudder. GM’s 8-speed is known for it, and the 10-speed reportedly does it too. The usual fix is a fluid flush first, then a new converter if it keeps happening.
