2022-2023 revised door panel upgrade
You know you can remove that airbag warning tag right? LOL
hopefully you put some better speakers in the doors and not the fake BOSE speakers like I have in my LT TB. They sound so bad. But what you did does look good. Your doors look like mine now.
Thats the point, upgraded interior, all except dash. Purchased Katzins red inserts and solid blk with grey stitch.
update install
Had the keep original harness in door all door (GM changed all plus to switches in harness) even thou they look alike.
Switch out all switches and reuse originals except power locks in front door panels!
Cut and splice drivers and passenger power lock plugs from new harness to original harness.
Cut door liner hole to except updated panel.
Remove plastic pin in door panel and replace 1 pin from original
Hey do you have the bracket part number that have to be replaced? Be awesome if you did
update install
I know this is an older post but I’m currently putting the ZR2 door panels on. How exactly did you wire the new harness to the original?
